biete ein Brother Mehteh in der Gr. XL an, leider falsche Größe geordert, kam heute an, wer noch ein schnelles Weihnachtsgeschenk sucht?
Abholung oder Versand möglich.
Karton ist original verpackt und noch nicht geöffnet.
999€
Ausführung und Farbe siehe Hp.
https://www.brothercycles.com/shop/frames/mehteh/
Features
Frame tubing: Reynolds 725 heat treated chromoly double-butted main triangle, ED coated
Brake compatibility: flat mount, 160mm max rotor size
Rear Dropouts: 12x142mm TA (included)
Seat post diameter: 27.2mm
Seat clamp diameter: 30mm (included)
Headset: 44mm, ZS44/28.6 upper, EC44/40 lower (not included)
Front derailleur clamp diameter: 28.6mm
Bottom bracket shell: 68mm bottom bracket, ISO threaded
Maximum tyre clearance: 700c x 50mm, 650b x 2.2"
Full-length cable housing guides for derailleurs and brakes
Stealth dropper post routing
3 sets bottle cage mounts on all sizes
Rear rack and mudguard mounts
Chainring clearance: up to up to 52-39-30t triple, 50-34t double, 48t single
Fork: 1.5″ – 1.1/8″ tapered steerer full carbon disc fork, mudguard/triple cage mounts, Dynamo routing and flip chip dropouts, 12x100mm TA (included)
Frame weight (medium): 2.2kg
Fork weight (uncut steerer): 0.55kg
