Hallo! Meinen Deutschen ist nicht sehr gut, folglich schreibe ich auf englisch
I'm intersted in a Nicolai Nucleon TFR but I have some questions:
What is the total weight och the frame if I choose enduro version with magnesium and titanium kit (which is the lightest possible, right) in size L, anodized color ?
What is the weight of each part (bottom bracket, rear hub, swingarm shock etc.) ?
What is the seatpost size?
What is the seatpostclamp size?
Is the rear hub 32 or 36 hole, can I choose that myself when I order?
How big is the tire clearence? 2.3, 2.4, 2.7?
ISIS is not consider the best bottom bracket (bb), is the frame coming with other kind of bb in the future (like squaretaper, octalink, integrated...)?
What ISIS bottom bracket is availeble in 100mm, ecxept for Truvativ Gigapipe DH if the bottombracket one day break?
Is the external chain a normal 9speed chain or do I have to use some Rohloff specific chain?
I'm thinking about a Pace RC41Fighter Suspension Fork 150mm with 524mm axle to crown (https://www.pacecycles.com/product.asp?catID=2&subcat=467) , will this fork fit this frame (in size)?
Is there any function to have a spindle on the cranks or can you remove it (drilling, screwing, sawing etc.) to save weight?
Can I buy the frame without cranks?
Can I buy the frame without shock?
What is the recomended stroke and size on shock?
Is the linkage linear or progressive?
Is the Camo color powercoat or anodized?
I need a deep insertion headset, 25mm right?
How often do I need to service the G-boxx?
I have heard rumors about Rohloff will release a lighter version of the speedhub (with less gears), have you heard anything about this?
My plan is to build a perfect allmountain enduro bike, as light as possible without compromising strenght. No big hucking or XC racing.
