Noch mal für alle die nicht bescheid wissen :
To assure the connection between the resorts of Morzine and Les Gets, different measures will be implemented this Summer 2013 for Mountainbikers.
1- A shuttle service which is adapted to the transport of bikes will run between the resorts of Morzine and Les Gets every day from june 28th till September 1st 2013 included.
- The access of to these shuttle buses will be reserved to the lift pass holders.
- They will run from at 8:30 to 6:00 p.m. (last departure Morzine) every day.
- Departure Morzine : bus stop at the bottom of the the telecabin of Pléney, stop Les Gets: Chavannes' gondola
-This shuttle service will run on saturday 22nd and sunday 23rd June. It will start again on june 28th as initially planned.
2 - The biking tracks between the resorts of Morzine and les Gets will be maintained and marked as usual.
3 - to increase a flow rate, a complementary solution with the chairlifts of Pléney (la Crusaz and les Mouilles) is proposed:
- the chairlift of la Crusaz will be opened for bikes from 28th june till 5th july at night (8:30 to 6:00 p.m).
- from July 6th, the chairlift of la Crusaz will run from 8.30 a.m to 10 a.m for bikes.
- the chairlift of les Mouilles will bridge the one of la Crusaz, the same opening hours to reach the top of Pléney.
