- 17. Oktober 2012
- 31
Bei mtbr.com hat jemand eine 7x XM-L T6 Lampe getestet welche seiner Meinung nach sehr hochwertig gebaut ist.
Oft hatten Lampen mit mehreren LED´s Probleme mit der Leistung. Es gibt sogar einen Themenstrang hier in diesem Forum in dem jemand beschreibt, dass seine Lampe mit mehr LED´s trotzdem weniger Lichtstärke erzeugte als seine Zweitlampe mit weniger angegebenen Lumen und einer geringeren Anzahl von LED´s.
Diese Lampe hier soll aber angeblich weitaus mehr leisten und folgende Werte wurden gemessen:
4A @ 8,4V sowie 6,6A @ 6.2v on high
"This purple&grey 7 XM-L2 draws some serious amps! 4A @ 8.4V, 6.6A @ 6.2V on high Thermal transfer seems very good, since it heats up in hand at home quite quickly, has 3 modes: high(100%)-mid(~35-40%)-low(~5-15%)-off cycle and hidden strobe, doesn't have battery indication, but just small green, orange & red leds turning around at the back of the light."
"The beam pattern seems to be due to reflector design a mix of flood & throw with a bit more flood.
Expect some decent flood & throw and with nice tint (comparing it with my MJ880 XM-L U2 clone from KD that seemed much more cooler white than this)."
"The light is relatively heavy 280g the head itself, the weight in the description is overstated (480g)."
It is powerful as LM site says - powerful enough due to amp draw:4A @ 8.4V, 6.6A @ 6.2V on high (32-36W).
You can estimate the output is high enough to expect something between 2000-3000lm (real).
Thermal path is the best one you encounter between Chinese lights: 7 led MCPCBs connected in series resting on a 5mm thick body of the light.
You get probably the most powerful light from China with nice tint, XM-L2 T6 emitters.
Lieferant:
http://www.lightmalls.com/powerful-7-cree-xm-l-t6-6000lm-3-mode-front-bicycle-light-lamp-cap-only
(The light is interesting indeed! Ebay is selling these as 9000lm trustfire / fandyfire bike light. )
Mehr Bilder vom Innenleben der Lampe und die Diskussion dazu hier:
http://forums.mtbr.com/lights-night...0lm-3-mode-front-bicycle-light-lm-884687.html
Es rentiert sich wahrscheinlich diesen Thread weiter zu verfolgen.
Lieferant:
