- 8. Mai 2003
- 32
Servus,
wieviel soll ich für dieses gebrauchte Bike bezahlen?
Seht ihr Schwachstellen bei den Parts?
http://www.ebay.de/itm/ROCKY-MOUNTA...e=STRK:MEBIDX:IT&_trksid=p2060353.m2763.l2649
Rocky Mountain Altitude 750 Msl Carbon Rally Edition 2016 size L used 5/6 turn, ticket garantie frame 03/2016 Frame SMOOTHWALL(TM) Carbon Front Triangle. FORM(TM) 7005 Series Custom Hydroformed Rear Triangle. ABC(TM) Pivots. Tapered Head Tube. Press Fit BB. Internal Cable Routing. ISCG05 Tabs. RIDE-9(TM) Adjustable Geometry Suspension Rate, size "L" Shelter film Fok Fox Float 34 CTD 3 adijust positions,lock out for up-hill, neutral for trail-open for downhill) 150mm. steering tube conical da 17cm. 1-1/5 - 1/8 shock Rock Shox Monarch Debonair high volume SMOOTHLINK(TM) Design 160mm. Rebound / Remote Trail Threshold Lockout / Adjustable Suspension haedset Cane Creek Fifteen Series: IS42mm Top / 52mm Bottom Tapered Stem Wake duo da 45mm Handlebar Renthal Fatbar Carbon riser da 10mm x740mm Grip ODI Ruffian Lock On nere Brake Shimano Xt Ice-Tec Hydraulic dischi Formula light 180 mm. Trigger Sram NX 1x11spd rear derailleur Sram NX X-Horizon 11V Type 3 2017 Chain Sram PC-1110 11V 2017 Crank Race Face Ride 175mm 32T 1x11spd Bottombrake Race Face Press Fit Cassette Sram NX PG-11-42 11V 2017 Wheels E-Thirteen TRS 27,5" gr.1670 Tires Front Maxxis High Roller II 3Compound EXO 27,5x240 Rear Maxxis Minion DHR II EXO TR 27,5x240 90% Seatpost Rock Shox Reverb 30,9 with remote. Saddle Specialized Phenom 130 Ti.
