JDEM
Coil is goil
Hab ich vorhin entdeckt: http://hucknorris.com/
Finde die Idee ganz cool - leicht, simpel und universell.
Procore hat zwar bei mir auch gut funktioniert, aber ist doch ein wenig schwer und aufwendig.
Versprochen wird ja nicht gerade wenig...
With Huck Norris the rocks gets the punctures when you ride!
More fun with tubeless MTB!
- No more punctures in tubeless MTB setup
- No more nasty dents to your rims
- No more hassle with tubeless setup
- No modification to your rim or glue needed
- No need for compressor to install tubeless anymore
- No need to over inflate the tires to avoid punctures. Use the pressure you want!
- No more downhill tyres on trail bikes
Specs
- 70g (27.5") 77g (29") weight
- For 21-28mm internal rim width, 27.5 and 29” wheels. Plus sized version available in three weeks and Fatbike version coming.
- Material specially developed for MTB use with actual scientists. Three times the impact energy damping than anything commercially available.
- Made in Finland. Patent Pending.
