Galerie: Mit dem 29er unterwegs
  • Ersteller Ersteller olli
  • Erstellt am Erstellt am
Das kleine Rohloff Speedhub Service Kit https://www.rohloff.de/en/shop/prod...t]=312&cHash=3e2a5d024567734c19e5187ae69edd2e
Description: Article. No.:
8190 Rubber grip for twist shifter "light" 1
8191 Twist shifter cable stoppers 1+14 for twist shifter "light" 2
8193 TX20 screws and clamp for twist shifter "light" 1
8194 Cable pulley for twist shifter "light" 1
8205 Drain screw 1
8231 Torque Arm screws with washers 1
8236 Axle-plate Torx screws (6 pcs.) 2
8243 Chainring spacers (5 units) 1
8248 Conversion kit Chain Tensioner 1
8251 Chain Tensioner jockey wheels 1
8257 Long mounting bolt + Distancing washers for chain tensioner 1
8260 Cable Guide 0° (straight type) with frame clamp 1
8262 Pipe Clamps for Art.No. 8240 1
8263 TS Axle nuts (M10 x 1) including washers 1
8268 Shifter cable set: 2x inner (1.1mm) + housing 1.8m 1
8271 Hub cables for Internal incl. tubes and ties 1
8274 Bayonet connectors, 1x male type, 1x female type 1
8275 Freewheel springs (2 units) 1
8295 Owners Manual Rohloff SPEEDHUB 500/14 1
8410 Oil change kit (with syringe, drain screw and filler hose) 1
8504 TX20 Torx T-Grip key 1
8506 Cable hook for shifter cables (internal gear mech) 1
8508 Sprocket tool 135/142/170/177 1
8540 Splined Carrier 1
8540 Splined Carrier with snap ring 1
8540s Splined Carrier "slim" with snap ring 1
8544 Splined Sprocket 16T 1
8570 Grub screw bayonet connectors 1
8573 Hub cable Easy Set (from Serial no. 25300) 1
8701 Empty Box 1
8704 Cable adjusters for cable box 1
8706 Washer and circlip for Chain Tensioner 1
8707 Bolt and circlip for locating fork (long torque arm) 1
8709 Bayonet springs 1
8710 Paper gasket kit for axle-ring 1
8713 Set of hub/shifter cable measuring aids 165 + 200mm 1
Ist aber nur das kleine, ohne innereien vom Speedhub ;)
Das kleine Rohloff Speedhub Service Kit https://www.rohloff.de/en/shop/product-detail?tt_products[product]=312&cHash=3e2a5d024567734c19e5187ae69edd2e
8205 Drain screw 1
8701 Empty Box 1
Verstehe ich nicht.
Speedhub heißt doch fahren und fahren. Und fahren.
Und wenn die Kettenschaltung eingefroren ist, fahren.
Das mit der R2 Trinkflasche war in Ordnung. Aber jetzt für die Italiener Werbung zu machen, geht zu weit!
Also entweder Label abkleben, unkenntlich machen oder nur für Deutsche Firmen im Deutschen Forum werben ☝️
Abba.... d Mafiosi habe Deckel..... Isse bei Matsche funktionieren beste👉🏻🖕🏻👈🏻
Hab die Elite schon seit Jahren... Mehrere Größen. Die sind top.
Inakzeptabel. Das Forum hat beschlossen: Trinkflasche ist der Werbeträger. Und wer Nahaufnahmen von der Trinkflasche macht, ist offensiver Werber.
Entweder du fährst ohne Trinkflasche, oder machst da eine andere rein :p
Also entweder steigst du auf Tee um
Oder trinkst Reinigungsmittel
Lässt die Flasche weg
Oder machst eine vernünftige Pose beim Werben
:aetsch:Inakzeptabel. Das Forum hat beschlossen: Trinkflasche ist der Werbeträger. Und wer Nahaufnahmen von der Trinkflasche macht, ist offensiver Werber.
:aetsch:
