Vincy
I love Jeffsy
First Look: Fox 2014
Die Neuheiten für das Modelljahr 2014
http://www.ridefox.com/filter.php?m=bike&t=forks&ref=topnav
Press Release:
FOX, the industry-leading ride dynamics company, has announced the release of two 2014 all-mountain products
with the 34 TALAS CTD 160 fork and FLOAT X CTD shock. The 34 TALAS features a completely redesigned TALAS
travel adjust system and the FLOAT X is a new reservoir air shock platform.
FOX FACTORY 34 TALAS CTD w/ Trail Adjust 160
The 34 TALAS fork has key design changes that translate to smoother travel and improved handling.
The updated CTD tune provides more damping support in each mode for better efficiency and control.
The TALAS system uses an air spring design similar to FLOAT, giving it superior bump compliance for
more comfort and traction on the trail. Mated to the air spring is a hydraulic travel adjuster that
provides quick, crisp travel changes between 160mm and 130mm.
All 2014 TALAS forks use the new travel adjust system.
40 FLOAT 27.5 FIT RC2
40 FLOAT 26 FIT RC2
http://www.mtb-news.de/news/2013/03/26/fox-40-float-rc2-federgabel-und-dhx-rc4-daempfer-vorstellung/
New for 2014
Mountain Bike Shocks
http://www.ridefox.com/filter.php?m=bike&t=shocks&ref=topnav
FOX FACTORY FLOAT X CTD w/ Trail Adjust Rebound
The performance advantages of the FLOAT Xâs reservoir design make it ideal for aggressive all-mountain riding.
The increased oil volume and dual piston damping system produce an incredibly responsive ride while maintaining
a consistent feel through rugged terrain. The base valve on the reservoir gives the Climb, Trail and Descend
modes a wide adjustment range to perfectly match trail conditions.
New for 2014
DHX RC4
New for 2014
Press Release:
- New TALAS travel adjuster
- 160mm/130mm travel range
- 3 on-the-fly settings with Climb/Trail/Descend
- Trail Adjust tuning range (0, 1, 2)
- Air spring pressure
- Rebound
- 15QR thru axle
- 26â and 27.5â wheel options
- 4.33 lbs. / 1,964 g (26â)
- Updated damping tunes for even greater control
- New and improved remote
- Improved air spring curve
- Low friction
- Crisp actuation with precise internal travel range
40 FLOAT 26 FIT RC2
New for 2014
- New air spring - 152g weight savings vs. Ti spring
- New chassis (crowns, upper tubes, lower legs) - 307g lighter
- New RC2 damper - lighter weight and revalved
- Total Weight Savings - 1.16lb / 526g
- Crowns reshaped for increased downtube clearance
- Details: air bleed system, mudflap mounting bosses, replaceable pinch bolt hardware, revised dust wipers
- New reservoir air shock platform
- Rebound
- Low friction hardware
- Remote option
- 0.8 lbs. / 365 g (8.5 x 2.5, no hardware)
New for 2014
- New piggyback air shock for aggressive All-mountain riding
- Wide CTD compression damping range and remote capability
- Shares damping features and improvements made to DHX coil shocks
- Easy maintenance air sleeve
- 70g lighter than DHX Air - 8.5 x 2.5" = 365g
DHX RC4
New for 2014
- Improved damping control, delivering more usable travel
- Reduced ending rate compression damping performs better with modern linkage designs
- Lower internal pressures for better small bump sensitivity and lower friction overall
- Better damping control at high temperatures
- New Air Assist
- New Air Assist Volume
