freecoaster von khe, also schau ich auf die khe homepage:
Reverse Freecoaster
Designed by Bruce Crisman.
Bruce puts in all his experience and ideas to make that hub the best and strongest Street Freecoaster ever.
The most important difference to the Geisha Street Freecoaster is the axle: The KHE Reverse will feature a 1pc hollow CrMo axle instead of the stud system.
9T driver
sealed bearings
14 mm hollow CrMo axle with allen key inside
36H or 48H
Available as RSD or LSD
Since the hub is still in the test phase, the specs are not yet obligatory.
As soon as the tests are successfully finished, we will start production.
"The Medium Gap allows you to go fast on backward stuff and doesn´t feel that sketchy cranking forward at all. I've been riding Freecoasters for quite a while now - and the "Reverse" seems to be the best shot!"
Timm Wiegmann
"The Reverse Hub has everything I've been looking for in a Freecoaster Hub. My capabilities for street riding have undoubtably increased thanks to the Reverse Hub."
Bruce Crisman
schwarz und weiß ab may 07 sagen sie noch
