- 24. Oktober 2010
- 2.841
Das Bildchen kenne ich ja, nur von Conti hört man nix.
Sonst trommeln die Hersteller doch schon immer ein halbes Jahr vorher.
Gruß Schwitte
auf was für Felgen?
Brake: Hayes stroker grams............................................. .......................228/246
Brake Rotor: kcnc razor 160/140............................................... ...............74/61
Brake Rotor Bolts: 6ti 6blue alloy............................................. ................?
Cables: powercords........................................ .........................................4g
Cassette: 11-36(probubly XX)............................................... ................. .....?
Chain: kmc sl10(or yaban)................................. .........................................240ish
Crankset: extralite e bones w/ homebrewed 35t..........................................502+4 0
Derlr (R): sram x.0 with afc pullys, alloy bolts + 09 med derailleur cage + carbon inner plate .......171g
Fork: Magura durin sl+starnut........................................ ............................1357
Frame: Carbon............................................ ..........................................hope fully low
Grips: bonty xxx light)............................................ .................................20
Handlebar: KCNC sc bone.(maybe something else at 620mm.......................115
Headset: Not sure yet maybe kcnc.............................................. ..............?
Pedals: Crank Bro's egg beater 2ti with ward axles.....................................182
Seat: Bonty evoke carbon............................................ ... ........................144g
Seatpost clamp: stock topper unless i have one made................................?
Shifters: xx rear(doesn't have a clamp yet).............................................. ....80g
Skewers: j&l flyweight (maybe quick release is in order..).............................32g
Stem: rotor sl2 w steel bolts(stock bolts suck! ill order ti to get the weight back)..........96+10?
Top cap/spacers: carbon and alloy bolt .................................................. ...12g
Tire (Front): currently schwalbe roc ron performance 2.25.............................485
Tire (Rear): kenda karma(best cheap xc rear tire ive ever ridden!)...................475
Wheelset: 1305g
Wheel Front: 592g
Hub: Mack 32h Super Light Front ........80g!..........................80g!........ ........80(verified!)!!
Rim: NoTubes ZTR Alpine .................................................. .......................326
Spokes: DT 1.8's (because a stiff wheel is a better wheel) w/ nipple's............186
Wheel Rear: 713g
Hub: Mack 32h Super Light Rear.............................................. .................200g!
Rim: NoTubes ZTR Alpine............................................ ............................. 327
Spokes: DT 1.8's w/ nipples........................................... ..........................186
Overall: should be 7900-8200g or 17.5lbs to 18.5lbs(an estimate)
Ich brauch mal Hilfe Männer,
ich will nach einem Jahr Continental Abstinenz wieder auf Altbewährtes zurückgreifen nur ich steig durch deren Produktbeschreibungskäse nicht mehr durch.
Gesetzt hinten ist der 2.2 Race King als SS. Muss ich da jetzt den normalen SS oder Race Sport nehmen?
Vorne will ich einen ähnlich voluminösen dicken fetten X-King verbauen, muss ich da den 2.4er nehmen? Wird das eng auf einer Alpine, oder geht das?
Sind die Race Sports mittlerweile dichtzukriegen mit Milch? Ich sehe bei R2 zum Beispiel, dass der 2.2 SS Race King schwerer geworden zu sein scheint.
