[COLOR="black"]Specialized Stumpjumper Comp 2006 vs. Canyon Grand Canyon 8.0 Mod. 2007 für einen alpen-X?!?!?[/COLOR]
Was ist eure Meinung, welches Hardtail???
http://www.specialized.com/bc/SBCBkModel.jsp?arc=2006&spid=21811
FRAME All new 06 M4 SJ Hardtail, M4 alloy ORE DT & TT, fully manipulated TT, SS, CS, Asymmetric Mono-stay seatstays, disc mount, replaceable derailleur hanger
REAR SHOCK N/A
FORK Fox F90RL, 90mm travel, air spring, compression adjust with lock-out, rebound adjust, lightweight alloy steerer
HEADSET 1 1/8" 10mm insertion alloy cups, sealed cartridge bearing
STEM 3D forged CNC machined, 4 bolt, 31.8mm OS clamp, 8 degree rise
HANDLEBARS Specialized XC Flat 31.8mm OS bar, 6066 butted alloy, 5 degree backsweep, 580mm width
TAPE/GRIPS Specialized MTB grip, black/charcoal
FRONT BRAKE Shimano XT BRM 765 hydraulic disc w/metallic pad, 6" rotor
REAR BRAKE Shimano XT BRM 765 hydraulic disc w/metallic pad, 6" rotor
BRAKE LEVERS Shimano for hydraulic disc
FRONT DERAILLEUR Shimano M-580 LX, 34.9 clamp, top swing, dual pull
REAR DERAILLEUR Shimano M-952 XTR, long cage, standard spring
SHIFT LEVERS Shimano M-570 LX, 9spd
CASSETTE FREEWHEEL Shimano HG50, 11/34
CHAIN SRAM PC-971 w/Power Link
CRANKSET Shimano M-760 XT Hollow Tech II, 2-piece crank/BB
CHAINRINGS 22A/32A/44A
BOTTOM BRACKET Shimano M-760 XT, Integrated with crank
PEDALS Shimano SPD 520 Clipless
RIMS Mavic XM317 Disc 26�, 32h, black, eyelets
FRONT HUB Specialized stout disc, sealed cartridge bearing, high/low flange, 32h
REAR HUB Shimano M525, QR
SPOKES DT Swiss 1.8mm Stainless, alloy nipples
FRONT TIRE Specialized FasTrack Pro 26x2.0", Aramid bead, dual compound, 120TPI
REAR TIRE Specialized FasTrack Pro 26x2.0", Aramid bead, dual compound, 120TPI
TUBES Specialized Ultralight, P/V
SADDLE Specialized BG Rival hollow Cr-Mo rails
SEAT POST 2014 butted alloy, black, 30.9 x 350/400mm
SEAT BINDER 34.9mm clamp, single bolt
http://www.canyon.com/mountainbikes/index.html?b=116
Rahmen New Fact6 Grand Canyon, 7005 Series Aluminium, Opti-Size Tubeset
Gabel FOX 32 FX
Steuersatz Integrated Headset
Schaltwerk SRAM X.9
Umwerfer Shimano XT
Schaltgriffe SRAM X.9 Matchmaker
Bremsgriffe Formula Oro K 24
Bremsen Formula Oro K 24 180/160
Naben Sun Ringlé Dirty Flea
Zahnkranz Shimano Deore 11-34
Felgen DT Swiss X455 Disc
Reifen Schwalbe Nobby Nic / Racing Ralph 2,25Â
Kurbeln Shimano Deore XT
Kettenblätter 44/32/22
Innenlager Shimano Deore XT
Vorbau Syntace F139
Lenker Iridium Ultralight
Sattel Selle Italia Filante
Sattelstütze Thomson Elite
Gewicht 10,50 kg
Das Stumpjumper Comp 2006 würde ich auch für 1500 Euro bekommen, wie das Canyon (auch 1500Â).
Kommt man mit einem dieser Bikes über einen alpen-X????? Oder doch lieber ein Fully? Komm von der StraÃe und fahr ansonsten ein wenig im Taunus rum.....
Vielen Dank für eure Beiträge!!
REAR SHOCK N/A
Gabel FOX 32 FX
Schaltwerk SRAM X.9
Umwerfer Shimano XT
Vorbau Syntace F139
Gewicht 10,50 kg
