Moin moin,
ich bin im Moment zufriedener Besitzer eines Cube Acid MTB und habe mir schon längerer Zeit überlegt, Upgrade auf ein Fully zu machen. Eigenlich wollte ich z. B. zu Radon greifen, aber letzte Woche bin ich auf folgendes Angebot gestoßen, hier ein paar Eckdaten.
Specialized Epic FSR Elite Carbon 29 (2015)
FACT 9m carbon, 29" geometry, FACT IS construction, FACT carbon front triangle, M5 alloy rear triangle, tapered headtube, carbon PF30 BB, full internal cable routing, 142mm dropouts, sealed cartridge bearing pivots, replaceable derailleur hanger, SWAT EMT tool cradle, 100mm travelFOX/Specialized remote Mini-Brain w/ AUTOSAG, inertia valve, BrainFade adjust, 205x53mm, 100mm travel
RockShox SID 29 Brain, Solo Air spring, tapered alloy steerer, bottom-mount BrainFade, rebound adjust, 15mm thru-axle, 100mm travel
1-1/8" and 1-1/2" threadless, Campy style upper with 1-1/2" lower, cartridge bearings
Specialized, forged alloy, 6-degree rise
Lenker: Specialized flat, 8-degree backsweep, 31.8mm
Specialized Sip Grip, light lock-on, half-waffle, S/M: regular thickness, Others: XL
Bremse vorn: Magura MTS, hydraulic disc, Hi Friction pad, alloy master cylinder, alloy caliper, Storm SL rotor, S/M: 160mm rotor, Others: 180mm
Bremse hinten: Magura MTS, hydraulic disc, Hi Friction pad, alloy master cylinder, alloy caliper, 160mm Storm SL rotor
Bremsgriffe: Magura MTS, alloy lever
Schaltung vorne: Custom SRAM X0, 2x10, high direct mount
Schaltung hinten: SRAM X0 Type 2, 10-speed, mid cage
SRAM X9, 10-speed
SRAM PG 1030, 10-speed, 11-36
Kette: SRAM PC 1031, 10-speed, w/ PowerLink, nickel finish
Custom SRAM S-2200, carbon, PF30 spindle, 22/36
SRAM, PF30, OS press-in bearings, sealed cartridge
Resin test ride, w/ toe clips, CEN std.
Räder: Roval Control 29, alloy, 21mm inner width, 32h
DT Swiss Revolution
Reifen: S-Works Fast Trak, 120TPI, 2Bliss Ready, folding bead, 29x2.2", Specialized Fast Trak Control, 60TPI, 2Bliss Ready, folding bead, 29x2.0"
Ultralight, presta valve
Sattel: Body Geometry Phenom Comp, hollow Cr-Mo rails, 143mm
Das ganze ist Ausstellungsstück eines grossen Fahrradhändlers, das Fahrrad ist neu, wurde nie bewegt und soll 3800€ kosten. Was sagt das Expertenpanel zu dem Preis???
Vielen Dank im voraus
Christoph
SRAM X9, 10-speed
DT Swiss Revolution
Christoph
