Du verwendest einen veralteten Browser. Es ist möglich, dass diese oder andere Websites nicht korrekt angezeigt werden. Du solltest ein Upgrade durchführen oder einen alternativen Browser verwenden.
I use the 2.4 UST (Queen and X-King) on Flow rims, it is probably one of the most worry-free setups out there.
The tyres sit quite tight in the bead, unlike non-UST tyres they will most certainly not burp or jump off the rim.
They can also be mounted with a standard floor pump which is a big advantage, just use a bit of soapy water to help the tyre snap into the rim bead.
I add 50ml of Stans Notubes to completely seal the tyre and to protect against thorns.
