- 25. Februar 2008
- 0
Hallo erstmal.
Bin neu hier im Forum und wollte mir bezüglich des Bikes
XPM-AM von KOGA MYIATA infos holn.
Modell XPM-AM
Segment Mountainbike
Kollektion 2008
Rahmenhöhen 41-46-51-56cm
Rahmenbeschreibung Completely hand-built lightweight TIG-welded full suspension frame. Tubes manufactured in triple-hardened and triple-butted 7005 aluminium. Equipped with integrated headset. New and improved Xtreme Pivot Management system, lightweight swing arm, equipped with air shock (travel 130 mm) and a replaceable rear derailleur hanger.
Gabel Fox 32 Float RL - 140mm travel - Lock Out - Rebound adjustment - Titanium color
Dampfung Fastrax air ARL 190 - Rebound adjustment - Lock Out
Steuersatz Tange Seiki industrial bearing - Integrated in frame
Farbe Chrome Red/Solid black//
Lenker Ritchey Pro Mountain Riser Oversized alloy - Black color
Vorbau Ritchey Pro - Black color
Griffe Ritchey WCS Foam comfort grips
Schalthebel (r) Shimano XT rapid fire plus - Two way and instant release - Optical gear display
Schalthebel (l) Shimano XT rapid fire plus - Two way and instant release - Optical gear display
Disc-/Hydraulic Bremsset (vorne) Shimano XT with Reach and Free stroke adjustment
Disc-/Hydraulic Bremsset (hinte) Shimano XT with Reach and Free stroke adjustment
Schalt-/Bremskabel Stainless steel inner cable -Flexible outer cable with teflon tube for light shifting
Rotor (vorne) Shimano XT ø180 mm
Rotor (hinte) Shimano XT ø180 mm
Kette Shimano XT Hyperglide for smooth shifting and riding - Neoprene Chainstay protector
Laufradsatz Shimano XT lightweight
Bereifung Schwalbe Nobby Nic Evolution 2.25 - Triple compound - Foldable
Schlauch Continental 47/62-559 - 42mm valve
Sattel Fi'zi:k Zeak - Magnesium rail - Black color
Sattelstütze Ritchey Pro Mountain ø31,6x400mm alloy - Black color
Sattelstützenklemmung Koga alloy QR
Kurbelgarnitur Shimano XT Hollowtech II - UltraLightweight - Hyperdrive chainrings for smooth and precise shifting: 44x32x22T - Silver color
Schaltwerk/Kassette Shimano XT 9 speed - Hyperglide for quick and smooth shifting - Sprockets: 11-12-14-16-18-21-24-28-32T
Schaltwerk Shimano XT shadow - Low profile design for more aggressive riding
Umwerfer Shimano XT
Flasche Tacx Source Solid - Easy refill
Flaschenhalter Tacx Allure Black
Gesamtgewicht ca 12,4 kg.
Was haltet ihr von dem Bike würde es recht günstig bekommen.
Anfangs war mein Interesse dem STUMPJUMPER FSR EXPERT nur bekomme ich das XPM-AM um nur knapp die hälfe!
Was haltet ihr von den verbauten Komponenten?
Wäre für Tipps jeglicher Art dankbar.
Modell XPM-AM
Kollektion 2008
Umwerfer Shimano XT
