Heyy
was haltet ihr eigentl. von dem
BigHit FSR II 2009.
Ich bin halt noch relativ neu in der Branche und will halt ein gutes DH/FR bike.
Hier sind ein paar daten: Was haltet ihr davon??
RAHMEN
BigHit FSR, M4 Premium Aluminum ORE TT/DT, full cartridge bearing pivots, ISCG mount, asymetrical rear triangle, 7.5" travel
FEDERBEIN
Fox Van R coil piggy back, 8.5x2.5", rebound adj., S:400, M:450, L:500
GABEL
RockShox Domain 302, 180mm travel, coil spring, external rebound adj., 20mm thru-axle w/ Maxle 360, 1-1/8" to 1.5" tapered alloy steerer tube
STEUERSATZ
1-1/8" to 1.5" Threadless, alloy, cartridge bearing
VORBAU
Specialized Aggro stem, 35mm extension, OS 31.8, 4-bolt, forged
LENKER
Specialized Big Hit rise bar, 31.8mm, 6 degree up, 9 degree backsweep, 680mm wide
LENKERGRIFFE
Specialized thin lock on grip, alloy bar ends
VORDERRADBREMSE
Avid Juicy 4R, full hydraulic, tool-less reach adjust, metallic pads, 203mm rotor
HINTERRADBREMSE
Avid Juicy 4R, full hydraulic, reach adjust, metallic pads, 203mm rotor
BREMSHEBEL
Avid Juicy 4R Hydraulic
UMWERFER
SCHALTWERK
SRAM X-9, 9-speed, short cage
SCHALTHEBEL
SRAM X-5, trigger, 9-speed
KASSETTE
Shimano HG50, 9-speed, 11-34t
KETTE
SRAM PC-971, 9-speed w/Power Link
KURBELSATZ
Truvativ Hussefelt, 170mm w/ SBC chain guide
KETTENBLÄTTER
34t, 4-bolt, compact 104mm pattern
BOTTOM BRACKET
Truvativ Howitzer XR, oversize sealed outboard cartridge bearing, 73mm shell
PEDALEN
Specialized Lo-Pro alloy
FELGEN
Specialized P-Disc, 32mm, 36h
VORDERRADNABE
Specialized Hi-Lo disc, 20mm thru-axle, 36h
HINTERRADNABE
Specialized disc, 135mm, machined flange, sealed cartridge bearing, bolt on, 36h
SPEICHEN
2.0mm stainless, black, brass nipples
VORDERREIFEN
Specialized Clutch SX 26x2.3", 60 TPI, aramid bead, cap ply, soft dual compound
HINTERREIFEN
INNER TUBES
Specialized 26x2.3", schrader
SATTEL
Specialized Enduro, 8mm hollow Cr-Mo rails, SL foam
SATTELSTÜTZE
6061 butted alloy, two-bolt, 0 offset, 30.9x300mm
SATTELSTÜTZKLEMME
7050 hard annodized alloy collar w/ QR, 34.9mm clamp ID, black
ANMERKUNGEN
Protective clear coat, derailleur hanger, reflectors, owners manual
Ihr könnts euch auch anschauen auf:
http://www.specialized.com/bc/SBCBkModel.jsp?spid=39214&eid=101
Vielen Dank schon mal im vorraus.
und seit bitte ehrlich =)
